Problem with Route Maps on 3560G
danbowencisco
Hi Everyone,
I have a 3560G with 3 VLANs connected to a Cisco ASA with the same VLANs. I want to have the switch interface for each VLAN as the default gateway for clients and then forward this traffic to the ASA for firewalling. Problem is, due to the switch knowing about the destination VLAN, it will send it directly and bypass the FW. So, I want to use route maps to forward the traffic received on say, VLAN 100, to the IP address of the FW in VLAN 100. This is how I am trying to do it.
This is my VLAN config on the switch and the default gateway:
interface Vlan100
ip address 10.11.120.14 255.255.255.240
This is my route map statement to force the traffic from 10.11.120.2 (on VLAN 100) to go to the FW interface on the same network.
access-list 100 permit ip host 10.11.120.2 any
route-map HIST-FTP permit 10
match ip address 100
set ip next-hop 10.11.120.1
The route map see's no matching packets when I ping from 10.11.120.2 to 10.11.121.3
SL-3560G-Switch#sh route-map
route-map HIST-FTP, permit, sequence 10
  Match clauses:
    ip address (access-lists): 100
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
This is my routing table on the switch.
Gateway of last resort is 10.11.120.225 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.11.120.225
      10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
C        10.11.120.0/28 is directly connected, Vlan100
L        10.11.120.14/32 is directly connected, Vlan100
C        10.11.120.216/29 is directly connected, Vlan216
L        10.11.120.221/32 is directly connected, Vlan216
C        10.11.120.224/28 is directly connected, Vlan224
L        10.11.120.226/32 is directly connected, Vlan224
C        10.11.121.0/28 is directly connected, Vlan500
L        10.11.121.2/32 is directly connected, Vlan500
When I ping from 10.11.120.2, I get this.
Pinging 10.11.121.3 with 32 bytes of data:
Reply from 10.11.120.14: Destination host unreachable.
Any help would be greatly appreciated.
Dan
6 Replies 6
Richard Burts
Dan
Can you verify whether 10.11.120.1 is reachable? If you do show arp is there an entry for this address?
Rick
Rick
it is reachable from the switch, ie the switch has an arp for it, but not from the host within that VLAN.
Dan
sorry I should have added, the host can ping 10.11.120.1, so therefore it gets an ARP for it.
Dan
quick update.
I can now ping it, but I think this is because the switch see's it as directly connected and therefore it is not going to the FW as I get no matching hits on the ACL applied to the ASA interface.
Also, my route map config gets no matching packets. Not sure why.
Dan
Did you add this command to the vlan interface?
ip policy route-map HIST-FTP
You will also want to add no ip redirects on the vlan 100 interface to avoid having the traffic be software switched.  You will never see matches on the route-map when the traffic is being hardware switched, but the traffic will be forwarded.
-Matt
brilliant.
I had tried to do it but it wasnt an available command. So, I downloaded a later code and added that command, now all works fine.
Thank you!
