Problem with router in rommon mode. Cisco 2851
geobax1969
rommon 2 > reset
c2851 platform with 1048576 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c2800nm-adventerprisek9-mz.124-15.T14.bin"
program load complete, entry point: 0x8000f000, size: 0x32b0904
Self decompressing the image : ################################################################################################################################################################################################################################################################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0003E9          0X00474800 C2851 Mainboard
0004F8          0X00753000 Integrated Service Engine NM
                0X0014B430 Onboard PVDM2 SIMM
                0X00262B0A Onboard VPN
                0X000021B8 Onboard USB
0004F4          0X00016804 Virtual Private Network (VPN) Module
                0X002C29F0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X01461AE6
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 22Mb.
Using 2 percent iomem. [22Mb/1024Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(15)T17, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 24-Jan-12 07:41 by prod_rel_team
Image text-base: 0x400AFA38, data-base: 0x439EF1F0
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Initializing memory for ECC
*** Level 2 Watch Dog Timeout ***ÿ
(The router reboots and the process start over again)
Leo Laohoo
Use a different IOS.
Make sure  your router does not have any network modules installed.
I'll give it try and post later... Thanks
