Problem with SVI and L2-Etherchannel
I am getting issue with one of my lab, includes SVI and L2-etherchannel. Not able to ping from client 10.0.0.1 to 20.0.0.1. attaching lab image.
Thank You!!!
@Sharanjeet_Kumar
 You need to add vlan 10 along the path  and add a default route on Sw3.
Take a look on the file I am attaching, it is working.
10 Replies 10
check below
Hi @Sharanjeet_Kumar
 Attach the Project here and let me take a look.
 Zip it first
Hi @Flavio Miranda ,
I am attaching the lab.
in SW1 and SW2 add VLAN
by
vlan 10
vlan 20
that solution
Note:- you need vlan20 svi in sw0 and sw3
thanks
MHM
@Sharanjeet_Kumar
Hi @Flavio Miranda,
Can you please share the screenshot  of text file you;ve changed on Sw3 and along the path
Problem is this file requiring lower version of packet tracer.
I will add the config in txt file.
Thank you so much. It worked!!
I was having issues with vlan on sw1 and sw2.
No thanks to me
LoL...
Do it by yourself' this make you more acknowledge in network.
Check vlan in each SW
When one not have vlan add it
And add svi in sw3.
