07-17-2023 08:36 AM
Hi guys, I got one question that maybe someone can answer here.
I was upgradeing 2960x switch that was master in a stack. It had two members, and one of the member upgraded successfully but the other one did not. Now when I type in “show switch” it says that one member is in stack but the other is not because of mismatch version.
I want to know what can I do to upgrade that switch that has mismatch version? Also, I want to know how can I found out IP address of that switch since the “show switch” only displays MAC address? Can I upgrade that switch just by connecting to it or is it possible to upgrade it only through the master in a stack?
I dont have much experience in networking so this question may seem like a joke to someone, but I could really use some help.
07-17-2023 08:48 AM
Hi @jommy
The IP address will belong to the master only. The member will an extension of the master. To fix the problem you mentioned, it would be easier remove the switch from stack, upgrade it individually and join it to the stack again.
07-17-2023 09:25 AM
