Problem with telnet port on 2611XM (NM-32A)
reiss wang
My Cisco2611XM with a NM-32A installed. To use command "show line", it show as below information.
Does it mean I just can set/use from telnet port33 (2033)?? Is it possible to begin from port1 and use port1-port32 (2001-2032)?? how??
thanks for help!
Router#show line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 0 0 0/0 -
33 TTY 9600/9600 - - - - - 0 0 0/0 -
34 TTY 9600/9600 - - - - - 0 0 0/0 -
35 TTY 9600/9600 - - - - - 0 0 0/0 -
36 TTY 9600/9600 - - - - - 0 0 0/0 -
37 TTY 9600/9600 - - - - - 0 0 0/0 -
38 TTY 9600/9600 - - - - - 0 0 0/0 -
39 TTY 9600/9600 - - - - - 0 0 0/0 -
40 TTY 9600/9600 - - - - - 0 0 0/0 -
41 TTY 9600/9600 - - - - - 0 0 0/0 -
42 TTY 9600/9600 - - - - - 0 0 0/0 -
43 TTY 9600/9600 - - - - - 0 0 0/0 -
44 TTY 9600/9600 - - - - - 0 0 0/0 -
45 TTY 9600/9600 - - - - - 0 0 0/0 -
46 TTY 9600/9600 - - - - - 0 0 0/0 -
47 TTY 9600/9600 - - - - - 0 0 0/0 -
48 TTY 9600/9600 - - - - - 0 0 0/0 -
49 TTY 9600/9600 - - - - - 0 0 0/0 -
50 TTY 9600/9600 - - - - - 0 0 0/0 -
51 TTY 9600/9600 - - - - - 0 0 0/0 -
52 TTY 9600/9600 - - - - - 0 0 0/0 -
53 TTY 9600/9600 - - - - - 0 0 0/0 -
54 TTY 9600/9600 - - - - - 0 0 0/0 -
55 TTY 9600/9600 - - - - - 0 0 0/0 -
56 TTY 9600/9600 - - - - - 0 0 0/0 -
57 TTY 9600/9600 - - - - - 0 0 0/0 -
58 TTY 9600/9600 - - - - - 0 0 0/0 -
59 TTY 9600/9600 - - - - - 0 0 0/0 -
60 TTY 9600/9600 - - - - - 0 0 0/0 -
61 TTY 9600/9600 - - - - - 0 0 0/0 -
62 TTY 9600/9600 - - - - - 0 0 0/0 -
63 TTY 9600/9600 - - - - - 0 0 0/0 -
64 TTY 9600/9600 - - - - - 0 0 0/0 -
65 AUX 9600/9600 - - - - - 0 0 0/0 -
66 VTY - - - - - 0 0 0/0 -
67 VTY - - - - - 0 0 0/0 -
68 VTY - - - - - 0 0 0/0 -
69 VTY - - - - - 0 0 0/0 -
70 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-32
the short answer is: you need to use 2033 thru 2064, 2001 thru 2032 are not available.
--> Line(s) not in async mode -or- with no hardware support:
1-32
