configuration of L2 P2P link over wan
priyanka.mum709
Need help for configuration of L2 P2P link over wan on Nexus 5K Switch
7 Replies 7
Reza Sharifi
Can explain what you are trying to do?
Is the WAN layer-2 or layer-3?
Hi Reza,
It's WAN layer-2 P2P configuration on Nexus 5k Switch
It's WAN layer-2 P2P link as I want extend my layer 2 traffic over the wan via L2 service provider link.
Priyanka
If WAN is layer-2, you can then simply trunk the ports on each side and use the same vlas in both locations.
Here is an example you can use for both sides:
iinterface Ethernet1/10
switchport mode trunk
switchport trunk allowed vlan xx-xx,xx,xx-xx
Hi Reza,
Thanks for your reply. This is pretty cool solution. Even I had a same thought, but I just have a small doubt here is, how my data will be safe? Is that any encryption I have to configure?
Priyanka
Hi Reza,
I am waiting for your responses. Could please help me to understand if there is any encryption has to be configured for sending the traffic over L2 link via trunk?
Priyanka
