Problem with trunk port connection between 3560 and Ericsson switch
yasser.fahmy
Hi there,
I've a strange problem that I hope someone can help me with. I had configured a trunk port between Cisco 3560 and Ericsson switch on the
3650 the port is configured as
 switchport mode trunk
same on the Ericsson side, everything was working great for a year until couple of days ago it all stopped working.
I rebooted both switches but it didn't work either.
when I switched the port on both sides to access port it started working again.
I don't have any problem with setting the port as access, but I can't understand the reason behind it.
does anyone have a clue.
thanks
Josh Sprang
You could try using "switchport nonegotiate"
That is the only way to shut off DTP which is Cisco Prop.
