Problem with VLAN Routing and ZPF
Hello, i am trying to do an assignment in Packet Tracer which requires me to create an ZPF Public-Private zone and also a vlan 10 so the zone Public-Private should only inspect packets going out. The ZPF works, but when i add an vlan configuration and an subinterface everthing stops working. The PDU stops at Layer 3:
1. The routing table finds a routing entry to the destination IP address.
2. The destination network is directly connected. The device sets destination as the next-hop.
3. The device decrements the TTL on the packet.
 And when i issue debug ip packet command it says that encapsulation failed. Is there anything i should also configure? Here is my config for router and switch. I will also attach my topology.
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname RA
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.129 192.168.1.139
ip dhcp pool vlan10_1
 network 192.168.1.0 255.255.255.128
 default-router 192.168.1.1
 dns-server 209.165.201.14
ip dhcp pool vlan10_2
 network 192.168.1.128 255.255.255.128
 default-router 192.168.1.129
ip cef
no ipv6 cef
crypto isakmp policy 10
 encr aes 128
 authentication pre-share
 group 2
 lifetime 1800
crypto isakmp key ciscovpnboro3 address 172.17.2.34
crypto ipsec transform-set R1-R3 esp-aes 256 esp-sha-hmac
crypto map R1-R3 10 ipsec-isakmp
 set peer 172.17.2.34
 set pfs group2
 set security-association lifetime seconds 1800
 set transform-set R1-R3
 match address 101
spanning-tree mode pvst
class-map type inspect match-any OUT-TO-DMZ
 match protocol http
 match protocol https
class-map type inspect match-all IN-2-OUT
 match access-group 102
policy-map type inspect OUT-TO-DMZ-POLICY
 class type inspect OUT-TO-DMZ
  inspect
policy-map type inspect IN-2-OUT-P
 class type inspect IN-2-OUT
  inspect
zone security IN
zone security OUT
zone security DMZ
zone-pair security OUT-TO-DMZ-PAIR source OUT destination DMZ
 service-policy type inspect OUT-TO-DMZ-POLICY
zone-pair security IN-2-OUT-PAIR source IN destination OUT
 service-policy type inspect IN-2-OUT-P
interface FastEthernet0/0
 no ip address
 zone-member security IN
 duplex auto
 speed auto
interface FastEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.1.1 255.255.255.128
interface FastEthernet0/1
 ip address 192.168.1.129 255.255.255.128
 zone-member security DMZ
 duplex auto
 speed auto
interface Serial0/0/0
 ip address 172.17.2.18 255.255.255.252
 zone-member security OUT
 clock rate 128000
 crypto map R1-R3
interface Serial0/0/1
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router eigrp 100
 network 0.0.0.0
 no auto-summary
router rip
ip classless
ip flow-export version 9
access-list 101 permit ip 192.168.1.0 0.0.0.127 172.17.5.0 0.0.0.255
access-list 101 permit icmp 192.168.1.0 0.0.0.127 172.17.5.0 0.0.0.255
access-list 101 permit tcp 192.168.1.0 0.0.0.127 172.17.5.0 0.0.0.255
access-list 101 permit esp 192.168.1.0 0.0.0.127 172.17.5.0 0.0.0.255
access-list 102 permit ip 192.168.1.0 0.0.0.127 any
access-list 102 permit icmp 192.168.1.0 0.0.0.127 any
line con 0
line aux 0
line vty 0 4
 login
end
version 12.2
hostname Switch
 switchport trunk allowed vlan 10
 switchport mode trunk
interface FastEthernet0/2
 switchport access vlan 10
 switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 shutdown
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
7 Replies 7
Mark Elsen
                  - Post here : Packter tracer discussions
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you i will post it there.
Is this packet tracer or real network?
Packet tracer
I dont know if packet tracer can support this task
Anyway
It hard task
For tcp traffic
You have to config two way if you select pass not inspect
You can use one way (only one zone pairs) if you use inspect
But be sure that traffic initiate from source zone.
For udp and other traffic you need two way zone pairs you can select pass or inspect
Traffic can initiate from both source and destiantion zone
That what you need.
MHM
If you would do it on actual device, would you need to apply security zone to sub-interface? I am asking because you can't do this in PT and my firewall worked until i configured sub-interfaces.
Zone firewall is l3 base'
So you need to apply zone member on each subinterface
Note:- any interface that not member of any zone it by defualt all any traffic
