Issues resetting password and secret password.
Sperry2023
Hi!
I recently got a new (to me) catalyst 2650. I went through the break process and enabled the secret password and the regular password. After that, I used “exit”, “copy run start.”
Then after a reload my passwords did not work. I assume this is because “copy run start” does not work the way I thought it did.
Any guidance would be greatly appreciated!
8 Replies 8
M02@rt37
Hello @Sperry2023
please provide us an output of that command:
# show version
At then end you will see this line:
Configuration register is XXXX with XXXX as 0x2102. If not you will need to modify this value.
under configuration terminal ;
config-register 0x2102
Best regards
The result of my initial commands was:
SW01#conf t
Enter configuration commands, one per line. End with CNTL/Z.
SW01(config)#enable secret password XXXXX
SW01(config)#enable password XXXXX
SW01(config)#exit
SW01#wr
00:02:13: %SYS-5-CONFIG_I: Configured from console by console
Building configuration...
[OK]
I then reloaded and the config did not save.
This is the result of show version:
SW01#show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 21-Oct-05 01:59 by XXXXX
Image text-base: 0x80010000, data-base: 0x80568000
ROM: Bootstrap program is C2950 boot loader
SW01 uptime is 2 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA6.bin"
cisco WS-C2950-24 (RC32300) processor (revision R0) with 21013K bytes of memory.
Processor board ID FOC1008Z0KD
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: XXXXX
Motherboard assembly number: XXXXX
Power supply part number: XXXXX
Motherboard serial number: XXXXX
Power supply serial number: XXXXX
Model revision number: R0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: XXXXX
Configuration register is 0xF
I then ran
SW01#config-register 0x2102
result:
Translating "config-register"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
Friend
You need to enter only one command
Enable password
Or
Enable secret
Not both of them.
enable password is the older (and less secure) implementation of a password for privileged level access.
enable secret is the newer (and more secure) implementation of a password for privileged level access.
If you enter them both then the enable password is ignored and enable secret is the password that will be used. So you might as well delete the enable password entry since it is doing nothing.
After doing copy run start you could do show start to see if your config changes were saved.
Rick
You are right but he did it in recovery password process so I think he make recovery process freezes.
So he must try one of them
That my Opinion here.
MHM
I then ran
You need to change the above config in config model:
#config t
(config)#config-register 0x2102
#end
#write
#reload
Once the switch come back make changes.
BB
balaji.bandi
Follow below guide and make sure you enter the password corectly.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
BB
You do
Enable password
And
Enable secret
Both ?
