Problem with VSS 6500
I get this message on my Cisco 6500 VSS.
I cannot find what this message is about.
This message come every 10-15 minuttes in my log.
%EARL_L2_ASIC-SW2_SPSTBY-4-DBUS_HDR_ERR: EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0E3D
This is my hardware:
VSS1#sh module switch 1
Load for five secs: 4%/0%; one minute: 4%; five minutes: 4%
Time source is hardware calendar, *14:39:20.134 DST Thu Aug 22 2013
Switch Number:     1   Role:   Virtual Switch Active
Mod Ports Card Type                              Model              Serial No.
  1    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1618BRHA
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1622DTWH
  3    4  WiSM 2 WLAN Service Module             WS-SVC-WISM2-K9    SAL1622DMTC
  4    6  Firewall Module                        WS-SVC-FWM-1       SAL1620CYE5
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  70ca.9bf1.6f9c to 70ca.9bf1.6fa3   4.1   8.5(4)       12.2(33)SXJ3 Ok
  2  2c54.2d82.dbf0 to 2c54.2d82.dc07   5.1   12.2(18r)S1  12.2(33)SXJ3 Ok
  3  0007.7d8c.8d78 to 0007.7d8c.8d87   1.1   12.2(18r)S1  12.2(33)SXJ3 Ok
  4  0007.7d8c.8a80 to 0007.7d8c.8a87   4.5   7.2(1)       3.1(10)      Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Policy Feature Card 3       VS-F6K-PFC3C       SAL1616ALTN  1.1    Ok
  1  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL161065G1  5.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL16138AMD  4.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
VSS1#sh module switch 2
Load for five secs: 3%/1%; one minute: 4%; five minutes: 4%
Time source is hardware calendar, *14:39:50.526 DST Thu Aug 22 2013
Switch Number:     2   Role:  Virtual Switch Standby
  1    5  Supervisor Engine 720 10GE (Hot)       VS-S720-10G        SAL1516BV5K
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1622DTW4
  3    4  WiSM 2 WLAN Service Module             WS-SVC-WISM2-K9    SAL1601ZXTX
  4    6  Firewall Module                        WS-SVC-FWM-1       SAL1622DRDK
  1  8843.e18a.1ca8 to 8843.e18a.1caf   4.0   8.5(4)       12.2(33)SXJ3 Ok
  2  5057.a8a1.ece0 to 5057.a8a1.ecf7   5.1   12.2(18r)S1  12.2(33)SXJ3 Ok
  3  e05f.b994.d5bc to e05f.b994.d5cb   1.1   12.2(18r)S1  12.2(33)SXJ3 Ok
  4  0007.7d8c.9090 to 0007.7d8c.9097   4.5   7.2(1)       3.1(10)      Ok
  1  Policy Feature Card 3       VS-F6K-PFC3C       SAL16095PZE  1.1    Ok
  1  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL16106QM0  5.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1620CSZN  4.1    Ok
  1  Pass
  2  Pass
  3  Pass
  4  Pass
IOS version:  s72033-adventerprisek9_wan-mz.122-33.SXJ3.bin
I hope somebody can help my to figure out of this.
Regard,
Christian
7 Replies 7
Simon Leigh
This message indicates that the EARL L2 ASIC detected an invalid header in the DBUS . This error is due to hardware that has failed, a misconfiguration of the module software, or invalid packets that were dropped because of an OIR operation.
Chances are this is caused by a hardware problem and advised that Module 5, VS-S720-10G, need to be replaced.
Log a TAC case with Cisco.
InayathUlla Sharieff
EARL_L2_ASIC-SW1_SPSTBY-4-DBUS_HDR_ERR EARL L2 ASIC #0: Dbus Hdr. Error occurred. Ctrl1 0xB08D0E3D
Explanation :
The message indicates there was an error detected by the L2 forwardingengine. This is most commonly either a poorly seated supervisor module or the supervisor could be failing. There is also a chance that one of the line cards is triggering the maligned packets on the Dbus but it's not as common as the supervisor being the issue. This is considers a low level hardware or connection issue and the troubleshooting should start with reseating the modules and supervisor.
If this does not resolve the log errors supervisor replacement will be the next step.
Inayath
****Plz rate if this info is helpfull******
I have tried to reload the chassis. Tat give me no impact on the fail message.
// Christian
1- Have you tried Re-seating the module? (I.e Removing the module and inserting it back ?)
2- If yes then go ahead and create the RMA with cisco.
Inayath
**** Plz rate all usefull posts****************
Yes, have tried to replace all the modules int he Chassis. Same problem. Ofcourse, All power off.
I am going with RMA and Cisco TAC
Thanks for answering.
Hi Christian,
Just to give you a heads up, replacement of a module may not necessarily solve the problem. You can think of these packets as bad packets that could be because of a bad card or a bad packet that was generated from somewhere within the network. I am not even sure of what module are you planning to replace - this is being detected by the supervisor of the standby chassis.
I would suggest that you open a TAC case not for the RMA but for troubleshooting. There is a way to capture these bad packets using the 6500s inbuilt ELAM capture tool. However, there are some changes that need to be done on a specific register before we can attempt to capture these packets and these changes should only be done by a TAC engineer.
With this capture, you can find out the origin of the packet, which card/port it came in from, what type of packet it is, the source/destination IP and mac, etc. Again, I would suggest that you have Cisco TAC troubleshoot this before asking for a replacement.
Aninda
Message was edited by: Aninda Chatterjee
Thanks alot for some good information here, Aninda.
Now I am going for Cisco TAC to get some troubleshooting.
Christian
