Problems after performing factory default-reset on 877
pureitservices
Hi All
I require some assistance with my 877 router.
I recently performed a  factory reset by pressing the rest button within 5 seconds of boot.  Since then I can get no connection to the router at all.  None of the interfaces appear to be active so cannot connect via ethernet.  I attached the console cable, booted the router and nothing appears on the screen in hyper terminal regardless of the terminal settings I use.  I have tried several PC's and several console cables to rule them out.  I have also tried to the CTRL+BREAK to try to get into ROMMON without success.  The OK light is on and the CD light flashes.
Does anyone have any ideas about what else I can try?
Thanks in advance
Keith
pureitservices
Anyone?
I would really appreciate some other ideas?
Many thanks
Keith
pureitservices
I have read that corrupt memory in the router could cause this type
of issue.  Does this sound feasible?  Would the OK light still be on?
