Problems Connecting a 3825 Router to a 3508 Switch
johnpaul76
I have a 3825 that I am trying to connect to a 3508 Switch via 1000BASE-SX.  I have an SFP in Gi0/0 of the router and a 1000BASE-SX model in Gi0/8 of the switch.  Both the switch and the router can see each other when using the "show cdp neighbors" command.  As a side note, I also have a NMD-36-ESW (36 port switch) in the router which is functioning normally. When connecting to that 36 port switch, I get an IP and traffic flows normally.
I've tried creating a subinterface on the 3825 and enabling a dotq encapsulation, but I do not get any connectivity.  I cannot ping the router from the switch, or vice versa.
I've included my running configs below.  Any help would be greatly appreciated.
Thanks!
3825 Router Configuration
Current configuration : 3396 bytes
! Last configuration change at 04:20:35 UTC Fri Aug 23 2013
hostname <removed>
boot-start-marker
boot-end-marker
card type t3 1
enable secret 5 <removed>
enable password <removed>
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.0.0.1 10.191.255.255
ip dhcp pool main-pool
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
dns-server 192.1.1.1 8.8.8.8
no ipv6 cef
voice-card 0
redundancy
controller T3 1/0
ip ssh time-out 60
ip ssh authentication-retries 2
interface GigabitEthernet0/0
mtu 1492
no ip address
duplex auto
speed auto
media-type sfp
negotiation auto
no mop enabled
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
interface GigabitEthernet0/1
mtu 1492
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
no mop enabled
interface Serial1/0
no ip address
dsu bandwidth 44210
interface FastEthernet2/0
no ip address
...(Removed for brevity)
interface FastEthernet2/35
no ip address
interface Vlan1
ip address 10.0.0.1 255.0.0.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 1 permit any
snmp-server community <removed> RO
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
password <removed>
login local
transport input ssh
scheduler allocate 20000 1000
end
3508 Switch Configuration
Current configuration:
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3508-1
ip subnet-zero
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
switchport mode trunk
interface VLAN1
ip address 10.0.0.2 255.0.0.0
ip directed-broadcast
no ip route-cache
ip default-gateway 10.0.0.1
snmp-server engineID local 0000000902000009E8E1C480
snmp-server community <removed> RW
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 4
password <removed>
login local
line vty 5 15
password <removed>
login
end
Andras Dosztal
Level 3
Level 3
Ge0/0 is not a switchport but a routed port, therefore it won't bridge to the vlan1 SVI. You have to assign an IP address to gi0/0.1 interface.
Sent from Cisco Technical Support Android App
Thanks for the response, but I think I'm missing something.  If I tried to give the subinterface on the router an address of 10.0.0.3, I get an error that IP address overlaps with Vlan1.  If I assign the subinterface an address of 20.0.0.1 and assign the Vlan1 switch to 20.0.0.2 they can ping each other.  However, in this case, a PC on the switch can't ping anything outside.
