Problems making changes in PDM behind ISA 2004
rmichiels
When I open PDM on a PIX501 on a machine behind ISA2004 I can do everything I want, except making changes. When I press Apply, after 60 seconds I get the message: PDM did not get a response from the server in the last 60 seconds.
When I connect my laptop directly to te PIX and open PDM I don't have this problem. It must be something in ISA2004 (I never had this problem with ISA2000 either). Can anybody tell me what to do to fix this? Open what port on ISA or what to configure on the PIX?
farkascsgy
Level 4
Level 4
ISA 2004 has a real time monitoring feature, and you can do some filtering for connection between PIX and your PC. From the log you can check that is there any blocked port by ISA or not, after this result we can go ahead a step...
bye
FCS
Please rate me if I helped.
