Problems to assign IP ADDRESS Cisco Switch Catalyst 3750.
flielguera
Good evening friends, please, if you can help me with an apparently basic problem: In my platform of switches I have several 3750 old people, in one of these switches I have several desktops. As of this morning, the PCs, which are connected to a Cisco IP phone, are not assigned IP (VLAN 1), the IP phone does receive IP and connects to the Call Manager (VLAN 13). SWITCH stations are configured in PORT-SECURITY mode. Anyone have any idea what is going on. If you can help me.
Reza Sharifi
For testing, remove the port security configuration from one of the interfaces, test and see if the PC can get IP.
Also, can you post the output of "sh run" from the switch?
Hello
As you dont state what prt-security is applied, as this time as suggsted by @Reza Sharifi  I would remove it
Acess Port example:
int x/x
switchport mode access
switchport access vlan x  <--data vlan
switchport voice vlan 13
spanning-tree portfast
no switchport port-security
Kind Regards
Paul
on a side note, what is the uptime of the switches ? Very long (> x years) uptimes can sometimes cause these symptoms. Rebooting the switch could help...
