happend Packet drop on HSRP using stack
hello Sir
i have a problem about packet drop. i have two 3850(version 3.3(5)se) switch using Stack.
i try to change from normal ip to hsrp ip in int vlan 10
ex)
->before
int vlan 10
ip addr 1.1.1.1 255.255.255.0
-> after
int vlan 10
ip addr 1.1.1.2 255.255.255.0
standby 10 ip 1.1.1.1
after changed the config, happend packet drop
did you have same like this case?
Francesco Molino
Are you seeing drop when you reach the vip?
I remember there was a bug. Can you upgrade your ios release which is old by the way and test it again?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
thanks your reply
but i can't upgrade and test again
could you share your knowledge about like IOS version or symptom?
Deepak Kumar
What is HSRP status while you faced packet drop? is Physical interface IP addresses are also facing packet drop?
Share the show commands output.
I know it was an issue in 16.1.x (something) version that when pinging HSRP address configured on the switch, intermittent packet loss can be observed. The issue is not observed when the physical address is being pinged.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I checked the BUG of 3.3(5)SE same like CSCUX39091
thanks~
