Problems with etherchannels
lcuchisanmillan
Level 3
Level 3
Hello all,
We are having a cosmetic problem with a etherchannel connecting 2 Cisco 6500, via 2 gigabit interfaces in each side. The link is okay and is it working fine, is more a cosmetic problem. The devices are directly connected and when we do a "show interfaces" we get the following:
     SWITCH 1        SWITCH 2
     _ Port channel X        _ Port channel Y
              4459995 packets input                                                              5038640 packets input
              2396802 packets output                                                             9470937 packets output
     _ Interface Giga X/1        _ Interface Giga Y/1
              3980467 packets input                                                               1930376 packets input
              1938976 packets output                                                             3963757 packets output
     _ Interface Giga X/2        _ Interface Giga Y/2
               7173942 packets input                                                              3989266 packets input
              3989205 packets output                                                             7172782 packets output
As you can see there the packet counters in the interfaces that form the Etherchannel are alright:
     The total of the input packets in SWITCH 1 interface X/1 and X/2 are similar to the total of the output packets in SWITCH 2 interface Y/1 and Y/2 and the total of the output packets in SWITCH 1 interface X/1 and X/2 are similar to the total of the input packets in SWITCH 2 interface Y/1 and Y/2.
The problem is with Port-channel counters:
     _ First, the input/output packets is not the total of its interfaces input/output packets
     _ Second one, input/putput packets of Port-channel X of SWITCH 1 does not coincide with output/input packets of Port-channel Y of SWITCH 2
Does anyone know if this is normal and why?
Thank you very much
danrya
Level 6
Level 6
Are there drops or errors on the EC's?  Can you attach the "show interface po x/x" and "show interface po x/x summary"?
Maybe that will shed some light on the issue.
Hello danrya,
We do not see any drops in the etherchannels, here you have the outputs:
SWITCH 1
#sh int PoX
  Port-channelY is up, line protocol is up (connected)
  Hardware is EtherChannel, address is XXXXXXXXXXXXXXX
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 11/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s
  input flow-control is off, output flow-control is off
  Members in this channel: Gi7/1 Gi7/2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 1w5d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 87552000 bits/sec, 18261 packets/sec
  30 second output rate 5623000 bits/sec, 9234 packets/sec
     11565866639 packets input, 7794362603329 bytes, 0 no buffer
     Received 3322152 broadcasts (2475613 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     9549561617 packets output, 4454444531302 bytes, 0 underruns
#sh int PoX summ
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface               IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* Port-channelX           0     0    0     0 65495000  13626 4199000  6882    0
NOTE:No separate counters are maintained for subinterfaces
     Hence Details of subinterface are not shown
SWITCH 2
#sh int PoY
  Hardware is EtherChannel, address is YYYYYYYYYYYYYYY
     reliability 255/255, txload 9/255, rxload 1/255
  30 second input rate 4932000 bits/sec, 8081 packets/sec
  30 second output rate 76591000 bits/sec, 15967 packets/sec
     15803657188 packets input, 7293008709881 bytes, 0 no buffer
     Received 43062517 broadcasts (13063671 multicasts)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     19179225172 packets output, 12941767311772 bytes, 0 underruns
#sh int PoY summ
*: interface is up
* Port-channelY           0     0    0     0 5105000  8541 81279000  16919    0
