Problems with File & Printer Sharing
mikeypo214
Community Member
I have RV 120W Wireless-N VPN Firewall and am having difficulty setting up the LAN.  I have successfully setup a site to site VPN and they are working fine. However, I am having difficulty on setting up my LAN, particularly communicating and file sharing between computers inside the same LAN.  I made this router as DHCP server and I can't figure out as to why I can't ping nor get to communicate the PCs under its LAN.  Can someone please help on resolving this issue?  Thanks!
Mike Po
Fabienne Stephanoff
Mike,
What type of device is this router? Is this the default gateway for the PCs in that vlan? Are those PCs directly connected to this device?
Cheers,
Fabienne
