Problems with L2 EtherChannel
maxim.alyakin
Hi all, I need some help to resolve a problem with L2 etherchannel -
when I add VLAN on Portchannel, this VLAN does not appear in config Members of this Po,
so after reboot Portchannel does not work:
"...and will be suspended (vlan mask is different)"
I try to simulate it on test switch in office, but problem does not appear!
Both switch are Catalyst3560G with same IOS.
1. SW in real network segment:
Model revision number           : D0
Motherboard revision number     : B0
Model number                    : WS-C3560G-24TS-S
Top Assembly Revision Number    : B0
Version ID                      : V03
*    1 28    WS-C3560G-24TS     12.2(46)SE            C3560-ADVIPSERVICESK9-M
ports config.:
interface Port-channel1
switchport trunk allowed vlan 622,633,1010,2002-2032,2036,2038,2040-2044
switchport trunk allowed vlan add 2046-2058,2060,2061,2063-2200,2202-2232,2235
switchport trunk allowed vlan add 2236,2238,2240-2244,2246-2258,2260-2400,3502
switchport trunk allowed vlan add 3504,4040
switchport mode trunk
arp timeout 900
end
#sh int po1 | i Mem
  Members in this channel: Gi0/9 Gi0/10 Gi0/11 Gi0/12 Gi0/13 Gi0/14 Gi0/15 Gi0/16
interface GigabitEthernet0/9
ip access-group 2009 in
mls qos trust dscp
arp timeout 900
channel-group 1 mode active
end
Add VLAN on Po1:
(config)#int po1
(config-if)#sw tr all vl add 999
View the result:
switchport trunk allowed vlan 622,633,999,1010,2002-2032,2036,2038,2040-2044
arp timeout 900
end
mls qos trust dscp
arp timeout 900
end
Gi0/9 does not has vlan 999 allowed.
Test Switch in office:
Model revision number           : G0
Motherboard revision number     : A0
Top Assembly Revision Number    : D0
Version ID                      : V05
Ports config., I copy-paste them from SW in real network:
end
3560G#sh int po1 | i Mem
  Members in this channel: Gi0/1 Gi0/2
interface GigabitEthernet0/1
mls qos trust dscp
arp timeout 900
end
Add VLAN on Po1:
3560G(config)#int po1
3560G(config-if)#sw tr all vl add 999
3560G(config-if)#^Z
View result:
end
mls qos trust dscp
arp timeout 900
end
So VLAN 999 exist on all Gi members of Portchannel and there are no problem with suspended ports after reboot.
Can anyone explain what Im doing wrong?
This issue often occurs in real network after SW cold-start.
6 Replies 6
Sebastian Helmer
Level 10
Level 10
I cheched some release notes but see no help there..
in the problem case, the vlan exist in the database, right?
I see no mistake from you side..I will keep you in mind
regards,
Sebastian
Hi Sebastian!
VLAN exist in DB,
#sh vl id 999
VLAN Name                             Status    Ports
999  VLAN0999                         active
125-101(config-if)#^Z
125-101#sh vl id 999
999  VLAN0999                         active    Po1
glen.grant
  Make sure the L2 vlan is created , use "show vlan" to check .   Also check to make sure the device is configured exactly the same on the other end of this switch .  I have seen times when you need to take the whole port channel down with a shut on the SVI and then no shut the port channel SVI to sync correctly.   Whats on the other end of this port channel ?
Hi!
As I posted above VLAN is created, does locally configuration on Switch depends on config. of remote end?  (I use transparent VTP mode) In this test in both case other SW is Catalyst4948 and I do not add test VLAN999 on this Portchannel.
I can't shut SVI, trunk configuration changes occur as every customer add in my network.
Thanks for reply!
Nandan Mathure
Level 7
Level 7
Please paste "show vtp status" and "show int trunk" from all concerened switches i.e  output from TEST and as well production environment. Also when u add the vlan to allowed list try shutting the range po with member interfaces and re-enable them together. let me know if that helps.
Hi!
Output from SW in real network:
(output omitted from ports not are in Po)
#sh vtp status
VTP Version                     : running VTP1 (VTP2 capable)
Configuration Revision          : 0
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 10
VTP Operating Mode              : Transparent
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0xD7 0x09 0xB4 0xB3 0x40 0x0A 0x1C 0x06
#sh interfaces trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Po1         on               802.1q         trunking      1
Port        Vlans allowed on trunk
Po1         622,633,999,1010,2002-2032,2036,2038,2040-2044,2046-2058,2060-2061,2063-2200,2202-2232,2235-2236,2238,2240-2244,2246-2258,2260-2400,3502,3504,4040
Port        Vlans allowed and active in management domain
Port        Vlans in spanning tree forwarding state and not pruned
Output from TEST SW:
3560G#sh vtp status
Number of existing VLANs        : 29
VTP Domain Name                 :
MD5 digest                      : 0xDC 0x43 0xC5 0xF0 0x6A 0x58 0x02 0x78
3560G#sh int trunk
Po1         622,633,888,999,1010,2002-2032,2036,2038,2040-2044,2046-2058,2060-2061,2063-2200,2202-2232,2235-2236,2238,2240-2244,2246-2258,2260-2400,3502,3504,4040
