problems with load_helper
tnitz
Community Member
                 I have a cisco 2960 switch.  Trying to recover a password.  Have tried several different ways to recover it.  I have let the switch load completely, then pressing the mode button waiting for the light to turn amber and then green.  I also have held the mode button down, plugged the switch back in until the mode light turns from amber to green.  Either way I will type flash_init. Then when I type load_helper I get a invalid command response.  The command load_helper isn't even listed.  Any hints on how to recover it would be greatly appreciated.
I accidentally hit answered!
graham smart
Level 4
Level 4
Have you tried
dir flash:
anyway?
if it works, just rename the config file and type boot.
ie:
rename flash:config.text flash:config:backup
boot
-Graham
Please note: My comments are simply suggestions. I cannot be held  liable for any loss of data, life or marbles due to following my  instructions.
Lice chat software for websites.
http://www.imsupporting.com
-Graham
Got a website? Need some live chat software?
5 Replies 5
graham smart
Level 4
Level 4
Have you tried
dir flash:
anyway?
ie:
boot
-Graham
-Graham
I tried both several time but no luck!  I accidentally hit answered!!
tnitz, if you do nothing does the switch appear to load its configuration properly? If not, then the flash may be corrupted and that may be why you're having issues.
I assume you've searched the Cisco website and read through the password recovery procedures for that particular switch and IOS version? I ask because I've had experience with different models having slightly different password recovery procedures. In addition, what commands you can run, such as dir flash:, can only be ran after you've initialized the flash and ran the load_helper. You must run the flash_init before you can execute a dir flash: command.
jason.kinney
Community Member
You will need to follow the commands, from the link provided below, but after you run the flash_init command prform the following:
Enter the command "dir flash:"  This command will list the files stored in flash.
Next, enter the command "rename flash:config.text flash:config.text.old"
Then, enter the command "boot"
You may have to press the "Enter" key if there is a long pause upon reboot
Finally, enter "n" when the switch prompts the following "Would you like to enter the initial configuration dialog?"
switch: flash_int
switch:  dir flash:
switch: rename flash:config.text flash:config.text.old
switch: boot
Would you like to enter the initial configuration dialog? [yes/no] no
Switch>
Tauhassan
Community Member
Hi, no worries, please follow the steps:
Restart the Switch and press MODE button Approx few Seconds
Step 1 Initialize the flash file system:
Type flash_init
switch: flash_init
Tauhassan_0-1665079016814.pngDisplay the contents of flash memory:
switch: dir flash:
The switch file system appears:
Directory of flash:
13 drwx 192 Sep 20 20XX 02:30:48 c2950-i6k2l2q4-mz.121-22.EA14.bin
11 -rwx 5825 Sep 20 20XX 02:31:59 config.text
18 -rwx 720 Sep 20 20XX 02:21:30 vlan.dat
Rename the config.text file
switch: rename flash:config.text flash:config.old
then type boot
switch: boot
You are prompted to start the setup program. Enter N at the prompt:
Continue with the configuration dialog? [yes/no]: SAY N
At the switch prompt, enter privileged EXEC mode:
rename cofig.old file to config.text
rename flash:config.old flash:config.text
you will see you old switch hostname
go to config mode
reconfigure your username and password
That's it
