Problems with trunking between Cisco 3560 and Cisco IBM Blade 3012
Luis Perez
Im having problems changing a connection between a Cisco3560 and Cisco IBM Blade switch 3012 actually the configuration is access in Cisco 3560 and trunk int Cisco 3012 when i change the connection to trunk i lose conecctivity to the servers connected in the 3012, i have changed the access from vlan 1 to the respective vlan in the access port of the servers
5 Replies 5
Reza Sharifi
The config on both 3012 and 3560 should be trunk, so you can carry all the vlans connected to the IBM chassis.
Can you post the non working config from both 3012 and the 3560?
Switch 3560
switchport mode trunk
Swittch 3012
The trunk comes up but i have a machine connected in the vlan 40 actually the port in 3560 is configured like mode access in this vlan and the port of the server in the 3012 is access vlan 1, i have changed this port access to vlan 40 but the server lose conectivity.
Hi Luis,
Is this IBM switch a BNT switch?
I dont know what BNT means, but the IBM switch is a Cisco 3012
hi Luis,
IBM has a switch called BNT http://www.redbooks.ibm.com/abstracts/sg247960.html?Open so I was not sure if that is your case or not.
Juan
