procedure 6500
alexispino
there any formal procedure for cisco to clean out a modular switch 6500, for cleaning of the modules???
Leo Laohoo
Define "clean"?  You mean literally CLEAN or techie-talk wipe-the-data-out "clean".
Dust clean room modules, although the site is clean, we are thinking of making aphysical cleaning of the modules, remove them from the chassis and an air blower to clean dust
If the room is already clean then you don't need to do anything further.  See attachement.
ohhh anyway are applying for the job will try to see how to argue that really does not need physical cleanup work
thank
