Programming packet tracer help.
ballmoney3
Community Member
First I am asked to reconfigure the start configuration Connect SW0 and SW1 together using the remaining gigabit ports with a cross-over cable.
I did that.
The next part asked to modify the switch priority of SW1 the minimum amount to make it STP root switch.
I used the command spanning-tree vlan 1 root primary
But get a error saying
Switch>spanning-tree vlan 1 root primary
% Invalid input detected at '^' marker.
Why won't it work and what will the the connection between the two switches be like ?
johnlloyd_13
Level 11
Level 11
hi anthony,
the command should be done in global config mode. see below:
Switch(config)#spanning-tree vlan 1 root ?
  primary    Configure this switch as primary root for this spanning tree
  secondary  Configure switch as secondary root
Switch(config)#spanning-tree vlan 1 root primary
this command will ensure that this switch has the lowest bridge priorty value, thus making it the root bridge.
are you creating a lab network wherein switches are connected in a triangular fashion?
