02-12-2012 01:07 PM - edited 03-07-2019 04:53 AM
Hi friends,
With out using any server, will DHCP be configured in cisco 2950/2960 switch?
I man cisco it self should work as a dhcp server also.
If any body help me, it would be great full....
Thanks & Regards,
Srinivas. N
02-12-2012 01:36 PM
Hi Srinivas,
Yes, even 2950 or 2960 Catalyst switches can be configured as DHCP servers. There is a limitation on 2950: this switch can have at most one SVI (Switched Virtual Interface) activated at any time. This means that a 2950 switch can provide DHCP Server services only for a single directly-attached VLAN. This limitation does not affect the 2960 which can have multiple SVIs activated.
Best regards,
Peter
02-19-2012 07:29 AM
Hi peter,
thanks for your support and i am not avare of it plz can u tell me config for 2960 switch?
Thanks & Regards,
Srinivas. N
02-19-2012 08:02 AM
02-19-2012 02:40 PM
Hi vijay,
Thank u very much for your support,
i configured as per your link... i am able to get the ip and dns also, but i am not able to get the gateway and no browsing.
Note:- my up-link switch 2950 is running with 115.119.187.35, gateway is 115.119.187.33 and vlan is 109.
the same is connected to cisco 2960 (192.168.50.2, gateway is 192.168.50.1and vlan is 1. executally there is no devise 192.168.50.1i mean gate way)
My requirement is
The 2960 switch, wihich is connected to 2950 (main switch), the same switch (2960) should pass the dhcp, dns for the another sigment
plz find out my config on below for 2960 and guide me to get result.
User Access Verification
Password:
TEM_2960_8Ports>en
Password:
TEM_2960_8Ports#sh run
Building configuration...
Current configuration : 3134 bytes
version 12.2
service config
no service pad
hostname TEM_2960_8Ports
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
system mtu routing 1500
vtp mode transparent
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.50.1 192.168.50.10
ip dhcp pool TEST
network 192.168.50.0 255.255.255.0
domain-name cisco.com
dns-server 121.242.190.180 121.242.190.211
lease 4
no ip domain-lookup
ip dhcp-server 192.168.50.2
crypto pki trustpoint TP-self-signed-2182349824
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2182349824
revocation-check none
rsakeypair TP-self-signed-2182349824
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10,20,30,109
interface FastEthernet0/1
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface GigabitEthernet0/1
interface Vlan1
ip address 192.168.50.2 255.255.255.0
no ip route-cache
interface Vlan109
no ip address
no ip route-cache
ip default-gateway 192.168.50.1
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
TEM_2960_8Ports#
Srinivas.
02-19-2012 02:54 PM
"default-router 192.168.50.1" should be configured under "ip dhcp pool TEST"
02-20-2012 08:45 AM
Hi Vijay,
As u sed i configured...
switch ip is 192.168.50.2 (vlan 1)
dns-server insted of 192.168.50.2, i have give 121.242.190.180 121.242.190.211 (my running dns)
i am getting ip and all but no browsing.....
plz tell me how to get browsing also?
Srinivas. N
02-20-2012 08:50 AM
Srinivas,
Are you performing NAT/PAT in your setup ( I dont see that on your running configuration although) . the IP address that you use in your pool are private addressing which cannot be routed into the network. so you got to translate that into a public IP which can be routed over the internet.
Details about Nat can be found here
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
-Vijay
02-20-2012 10:48 AM
Hi vijay,
I under stand, but cisco 2960 will not support nating, than how can i servey...... ?
is there any other way?
Best regards,
Srinivas.
02-20-2012 12:54 PM
You'll have to add a router or firewall to perform your NAT.
Regards.
Alain
02-20-2012 06:21 PM
Check your PCs if they get a default gateway. In your DHCP pool configuration you are missing the default-router statement.
ip dhcp pool TEST
lease 4
