promiscous port
message4mayank
Whether below config on catalyst 4500 switch is ok ? port type is access.
Do I need to remove switchport nonegotiate command or its ok ?
interface <<interface>>
 description <connected to firewall>
 switchport private-vlan mapping <<primary_vlan>> <<secondary_vlan>>
 switchport mode private-vlan promiscuous
 storm-control broadcast level 60.00
 spanning-tree portfast
 no shutdown
5 Replies 5
sachintambat
Config is ok.
Its ok If you keep switchport nonegotiate, it as its stops DTP negotiation.
-Sachin
whether promiscuous port automatically stops trunking  and thatst why removing "switchport nonegotiate" will make no difference ?
You can remove it if you want DTP negotiation to be required, if you have trusted device at other end then remove it.
we have firewall at other end..
Remove switch port nonegotiation then
