Pruning not removing vlans in forwarding state on trunk
mojogar
I have 2 switches with a trunk between them (both ports set to <sw mode trunk>, <sw nonnegotiate>).  One is a 3650 and the other is a 2960.
The 3650 is in VTP server mode
The 2960 is in VTP client mode (both ver 1)
Pruning is enabled on both switches
The 2960 switch has only 2 vlans enabled in it of a network total of 15.  Here I am showing the ports that are in vlans on the 2960:
VLAN Name Status Ports
1 default active Gi1/0/25, Gi1/0/26, Gi1/0/27, Gi1/0/28, Te1/1/1, Te1/1/2
4 athletic active
5 student active
11 production active Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8
Gi1/0/9, Gi1/0/10, Gi1/0/11, Gi1/0/12, Gi1/0/13, Gi1/0/14, Gi1/0/15
Gi1/0/16, Gi1/0/17, Gi1/0/18, Gi1/0/19, Gi1/0/20, Gi1/0/21, Gi1/0/22
Gi1/0/23
12 guest active
13 prod-wifi active
328 VLAN0328 active
329 VLAN0329 active
688 VLAN0688 active
Here I am showing the output from the interface trunk on the 3650:
Port Mode Encapsulation Status Native vlan
Te1/0/40 on 802.1q trunking 1
Port Vlans allowed on trunk
Te1/0/40 1-4094
Port Vlans allowed and active in management domain
Te1/0/40 1,4-5,11-13,328-329,688
Port Vlans in spanning tree forwarding state and not pruned
Im perplexed as to why pruning is not working
To fix this, I turned off VTP pruning globally and then re-enabled.
Mark Malone
You only need to enable it on the server in VTP, once it show in vtp status as enabled there it passes it to the clients from what i remember , but you may be hitting some bug if its not working you could debug vtp to see whats happening it may give more info , you can always manually prune which is usually more preferred as its user controlled , switchport trunk allowed vlan
Just one thing the vlans names match exactly on both switches yes no white spaces or typos as that would cause it not to prune correctly as the DB would be diff on each switch
