PTP versus PTPv2
mschneid
i am looking for a clear Statement which product line Nexus and Catalyst  supports PTPv2
my Feeling is  that in some docs PTPv2 is treated an mentioned only as PTP
and like for cat3850 AVB is mentioned - but i am not sure if 1588v2 is then supported or not
thx for some help
best r m
No ptp v2 mentioned
Nexus 7000
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/system-management/guide/b_Cisco_Nexus_7000_Series_NX-OS_System_Management_Configuration_Guide/b_Cisco_Nexus_7000_Series_NX-OS_System_Management_Configuration_Guide_chapter_01000.ht...
No ptp v2 mentioned
Nexus 5000
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/system_management/521_n1_1/b_5k_System_Mgmt_Config_521N11/b_5k_System_Mgmt_Config_521N11_chapter_0110.html
ptp v2 mentioned
Nexus 5500
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/system_management/6x/b_5500_System_Mgmt_Config_6x/b_5500_System_Mgmt_Config_602N12_chapter_0110.html
ptp v2 mentioned
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/white-paper-c11-733921.html
Cat 6504/6504
No PTP at all ?
Cat 3850
I found
AVB
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/configuration_guide/b_163_consolidated_3850_cg/b_163_consolidated_3850_cg_chapter_01000010.html
and 1588 is mentioned here – but not sure if that V2
no PTP at all
cat 2960
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/15-0_2_se/release/notes/OL25301.html
ginliu
Those 3850 models supportiing AVB is currently not PTPv2 capable. They are supporting gPTP.
Are their any plans to support PtP v2 on the Cat 3850?  Thank you
Hi, C3850 mgig skus are supporting both avb and ptpv2 now. So does C9300.
