public key authentication / 4096 bits
stuartkendrick
I'm trying to enable public key authentication to my gear.
Documentation suggests that IOS supports 4096 bit key lengths ... but I see the following error if I try to enter 4096 bit keys (2048 and 1024 work fine):
switch(config)# ip ssh pubkey-chain
switch(conf-ssh-pubkey)# username foo
switch(conf-ssh-pubkey-user)# [...]
% SSH: Invalid keyhash data
I've replicated this under:
Cat2960X / IOS 15.2(4)E
Cat4500X / IOS-XE 15.2(4)E
Is anyone successfully implementing 4096 bit keys under IOS?
--sk
Yes, it works with 4096 bit keys. I assume that you are just missing the right way to paste your key.
When in "conf-ssh-pubkey-user" mode, you first have to specify "key-hash" or "key-string", depending what you want to put in. If you use the key-string, IOS automatically converts it to a key-hash.
OK, with Karsten's encouragement, I got this working.  For posterity, here is what I did:
IOS
linux> ssh-keygen -lf ~/.ssh./id_rsa.pub -E md5
2048 MD5:c8:25:cd:90:c8:6b:4c:48:a0:38:a3:8a:e5:67:75:60 stuart@vishnu (RSA)
ios-switch(config)# username stuart privilege 15 password 0 secret
ios-switch(config)# ip ssh pubkey-chain
ios-switch(conf-ssh-pubkey)# username stuart
ios-switch(conf-ssh-pubkey-user)# key-hash ssh-rsa c825cd90c86b4c48a038a38ae5677560
ios-switch(conf-ssh-pubkey-user)# end
ios-switch#
Notice:
- Username must already be defined before entering the ssh key info
- Specify the 'md5' flavor of fingerprint (the default sha256 didn't work for me for 4096 bit keys)
- Remove the colons ':' from the hash before applying it to the switch's running-config
- I dodge the whole 'copying & pasting 250 characters at a time' issue by using the key-hash
NXOS
Create a file on a host:
host> cat /tftpboot/Cisco-Files/my-account-details
username stuart password 0 secret role network-operator
username stuart sshkey ssh-rsa {insert contents of id_rsa.pub here} stuart@company.com
end
And then upload that file with something like:
nxos-switch# copy tftp://10.1.2.3/Cisco-Files/my-account-details running-config
Notice:
- I dodge the whole 'copy & paste ~250 characters at a time issue' by uploading a file
