Purpose of NVI Interface
anonuevo_rex
Hi Guys,
I just want to ask what is the purpose of the NVI interface? It appears on the lists of my router interfaces after I configure NAT. I noticed that it replicate the IP address of my NAT outside interface. As a result, I can't ping my point-to-point router. I tried to remove the IP Address but there's no command "int NVI #".
BTW, this was done on GNS3.
Thank you so much
Rex
johnlloyd_13
Level 9
Level 9
hi rex,
were you able to ping prior applying NAT?
make sure ports are unshut and on the same IP subnet.
here's a useful link explaining NVI interface:
https://supportforums.cisco.com/sites/default/files/legacy/0/8/0/60080-NAT%20Virtual%20Interface.pdf
Hi johnlloyd_13
Thank you so much for this. I was able to fix this by recreating everything that I've started in the GNS3. I think its bug on the GNS3 since  I was able to do ping prior applying NAT and I make all ports are unshut and they're on the same IP subnet.
I wondering if NVI interface is still on the ISR G2 routers today.
Thank you so much
Rex
Hi johnlloyd_13
Thank you so much
Rex
