Putty connection using gigabit port
sploofer13
I have seen this once before but I have just seen it happen twice in one of our classrooms and I am confused.
Each student had a console connection to their router. The router was then connected to a switch via the gig port. When the students brought up putty and selected 'serial' the output was from the switch. If I disconnected the connection between the switch and the router both putty connections froze.
Through a cobination of rebooting/recabling the output then  came from the router.
How? Why?
Hello
Do the clients also have a network connection active as the same time as their console putty connection.
Can you elaborate on the actual setup please if applicable ( ie- use of a terminal server etc)
res
Paul
Kind Regards
Paul
