PVDM3 led status Amber in 2901 Router??
syrnrsc01
we have inserted pvdm3 module in to the 2901 router
but its LED status is showing Amber continuolsly.
I would like configure the FXS card but I am not able to get dial-peer command.
Can any ony help?
Its sh diag command giving the following output.
/#sh diag
Slot 0:
        C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time 00:58:11 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC16310CSA
        Hardware Revision        : 1.0
        Part Number              : 73-11834-09
        Top Assy. Part Number    : 800-30795-05
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2901/K9
        Version Identifier       : V05
        CLEI Code                : CMMHB10ARA
        Processor type           : C1
        Chassis Serial Number    : FGL16312126
        Chassis MAC Address      : 6073.5c26.7440
        MAC Address block size   : 72
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 33 31 30 43 53 41 40
          0x10: 06 17 41 01 00 82 49 2E 3A 09 C0 46 03 20 00 78
          0x20: 4B 05 42 41 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 30 31 2F 4B 39 89 56 30 35 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 42 31 30 41 52
          0x50: 41 09 C1 C2 8B 46 47 4C 31 36 33 31 32 31 32 36
          0x60: C3 06 60 73 5C 26 74 40 43 00 48 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 65 40 01 25 41 00 87 42 00
          0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
          0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
          0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 01 1D 42
          0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
          0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
          0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11576-03
        Board Revision           : C0
        Fab Version              : 03
        PCB Serial Number        : FOC162257KD
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-16
        Version Identifier       : V01
          0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 32 32
          0x20: 35 37 4B 44 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        3rd generation - FXS DID Voice daughter card (2 port)
        Top Assy. Part Number    : 800-30501-02
        Board Revision           : A0
        Fab Version              : 07
        PCB Serial Number        : FOC1350420M
        RMA History              : 00
        Product (FRU) Number     : VIC3-2FXS/DID
        Version Identifier       : V02
        CLEI Code                : IP9IAB3CAB
        Longitudinal Calibration : 01 10 10 4F 8D 10 10 8F
                                   9F
          0x00: 04 FF 40 06 21 41 01 00 C0 46 03 20 00 77 25 02
          0x10: 42 41 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 33 35 30 34 32 30 4D 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 32 46 58 53 2F 44 49 44 89
          0x40: 56 30 32 20 D9 02 40 C1 C6 8A 49 50 39 49 41 42
          0x50: 33 43 41 42 D3 09 01 10 10 4F 8D 10 10 8F 9F FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
Its sh running-conf command giving the following output.
/#sh running-config
Building configuration...
Current configuration : 1228 bytes
! Last configuration change at 06:29:29 UTC Fri Feb 7 2014
version 15.1
hostname /
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2901/K9 sn FGL16312126
hw-module pvdm 0/1
username cisco
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
ip address 172.169.2.152 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
scheduler allocate 20000 1000
end
and sh flash giving me the following output.
/#sh flash
-#- --length-- -----date/time------ path
1     74503236 Jul 30 2012 20:08:54 +00:00 c2900-universalk9-mz.SPA.151-4.M4.bin
2         2903 Jul 30 2012 20:21:54 +00:00 cpconfig-29xx.cfg
3      3000320 Jul 30 2012 20:22:10 +00:00 cpexpress.tar
4         1038 Jul 30 2012 20:22:18 +00:00 home.shtml
5       122880 Jul 30 2012 20:22:26 +00:00 home.tar
6      1697952 Jul 30 2012 20:22:40 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Jul 30 2012 20:22:54 +00:00 sslclient-win-1.1.4.176.pkg
176730112 bytes available (79757312 bytes used)
Leo Laohoo
Duplicate posts.
Go here:  https://supportforums.cisco.com/thread/2266233
confreg01
  •  Page not found
Page not found
The page you are trying to access was not found. Please check your URL for typos and try again.
