Pvlan on ISR4451 using trunk
gpardoen
Has anyone already tried to use private vlan on ISR4451 using a switch module?
Is there any guidelines to follow? Especially regarding the configuration of the ethernet-internal links, promiscuous port, promiscuous on trunk support? and BDI vs SVI.
In our setup, we are connecting an ESXi server on the switch module which will be configured with private vlan and as soon as we enable this private vlan configuration on the ESXi, the communication breaks. At this stage, BDI is configured on the router side, and the interconnect carry the vlans in a trunk.
Few caveats of the setup:
- Internal interconnect between switch module and router is just a trunk, again no support for trunk promiscuous, so no one seems to take care of the  pvlan secondary to primary mapping going out on the promiscuous? Suggestion? move the L3 to the switch module, and route in between?
- Due to the lack of support for private vlan on trunk, the primary and the secondary vlan are allowed up to the ESXi. Letting the ESXi the choice of using the primary directly (ie without using pvlan esxi config), and using the secondary (i.e. with activating the pvlan config and using the port group associated to the secondary vlan)
Thanks in advance for your help
Config detail
switch module side:
vlan 24
 name xx
  private-vlan primary
  private-vlan association 28
vlan 28
 name xx
  private-vlan isolated
! Internal connections towards the router, configured as trunk.
! No support for trunk promiscuous? Who is doing the secondary to primary mapping?
interface GigabitEthernet0/25
switchport mode trunk
switchport protected
spanning-tree portfast trunk
interface GigabitEthernet0/26
! Trunk towards the ESXi server allowing both primary and secondary.
! This is 'workaround' to allow both primary and secondary vlan up to the ESXi.
! Testing shows that it gives the right isolation (from a ESXi perspective).
interface GigabitEthernet0/15
switchport trunk native vlan 998
switchport trunk allowed vlan 24,28
switchport nonegotiate
no cdp enable
On the router side:
interface Ethernet-Internal1/0/0
description internal connection to switch module
no negotiation auto
no mop enabled
no mop sysid
service instance 24 ethernet
 encapsulation dot1q 24
  rewrite ingress tag pop 1 symmetric
  bridge-domain 24 split-horizon group 0
interface BDI24
vrf forwarding <VRF>
ip address xxx
no ip redirects
ip sticky-arp ignore
no ip proxy-arp
standby version 2
standby 24 ip xxx
standby 24 priority 110
standby 24 authentication md5 key-string xxx
no cdp enable
astapell
Hello gpardoen,
I had the same problem :-)
The SM can support both SVI and private-vlan mapping with ipservices license.
I didn't manage to pass pvlan over the internal connection. As a result I'd move L3 to SM and perform routing.
for the SM:
interface Vlan24
 ip address xxx
 standby 24 ip xxx
 private-vlan mapping 28
interface Vlan99
 ip address yyy
In the host create the related bridge-domain:
interface BDI99
 ip address yyy
 no cdp enable
 service instance 99 ethernet
  encapsulation dot1q 99
  bridge-domain 99 split-horizon group 0
if you enabled platform switchport svi just replace the host configuration with Vlan99 and allow vlan over Eth-Int1/0/0
astapell
Hello gpardoen,
for the SM:
interface Vlan24
 ip address xxx
 standby 24 ip xxx
interface Vlan99
 ip address yyy
interface BDI99
 ip address yyy
 no cdp enable
Thanks astapell, this is indeed an interesting workaround.
I will try it and let you know.
I got the confirmation from Cisco TAC that private vlan is only supported on the SM card and consequently private vlan awareness is lost when traffic leave the Switch Module. Therefore, the SVI related to pvlan needs to be terminated on the SM. Then, to route out, using a L3 interconenct is indeed a working solution.
