pvlan routing with no router 3750
beartoe1900
Can community pvlans route traffic to each other through the transparent SVI without a router connected on a single switch? Routing rules would be based on ACLs
Pvlan (Community) 250 <---> Pvlan (Community) 260
For some reason I cannot get this to work. My understand is that the SVI would route the traffic based on the ACL between vlans
Ron
Jerry Ye
Community VLAN are not allow to communication with each other on the switch (blocked at L2). Unfortunately, SVI doesn't support the local proxy-arp command which should do the trick on the router.
jerry
Jerry Ye
jerry
Actually, for all others struggling with routing on pvlans.....enabling local proxy arp and ip proxy arp on the primary pvlan interface fixed the issue. All routing is now handled through ACLs
how do it remove the correct answer link....
