PVST to MST
Psmurali89
Hi All,
I got 3 existing stack switches in MST with the below config.
spanning-tree mode mst
spanning-tree mst configuration
name xxxx
revision 1
instance 1 vlan 1-4094
spanning-tree mst 0-1 priority 8192
We connected another standalone switch to stack1 and by mistake we configured as PVST. All switches are L2 only. I want to change this one switch from PVST to MST using the same config above. Will this have impact on all other 3 stack switches? I will be making this change in maintenance window anyway.
17 Replies 17
Hi Paul,
Thank you very much detailed explanation and it is very helpful.
Just to confirm, if I change DC2 from PVST to MST using the same priority of 8192 as DC1, the DC1 should still be the root for vlan810 (I have only 2 VLAN's between DC1 & DC2 and they both are in same state), which means
DC2 Twe1/0/10 will be Root,
          Gi1/0/3 will be FWD
DC1 Twe2/0/22 will be Desg
         po6 will be root
So this change will not cause any major issue (am planning to do it out of hours just in case)?
Hello
@Psmurali89 wrote:
Hi Paul,
FYI DC1 is NOT the root for vlan 810, its whatever is attached to DC1 PO6 that is.
DC2 root port is via Twe1/0/10 interface  to wards  DC1
DC1 root port is via PO6 interface towards "another switch"
I don't have a full topology of your network, but based on the output you have provided, then no it should not cause an issue, however I would "Strongly suggest to perform this under a change window"
Kind Regards
Paul
Hi Paul
Thank you very much.
