QinQ 802.1Q I think I am not understanding it
merrittr
Hi All
I have set up one port (packets ingress) at the dot1Q tunnel all the packets are test generated so I know they will all egress via another port set up as the trunk port  so what I am seeing is all the packets captured via tcpdump on the ingress port have a vlan tag 1-4095 (I generate 4095 pkts all with a vlan tag 1-4095 in order. now on the egress port I have another computer tcpdumping that interface and i see the same 1-4095 vlan tags even though the qinq is supposed to be additionally taging them into vlan 20 ... am I missing something?
Oh... Very well, then.
To anyone intending to do some serious network experiments: Avoid Windows, use Linux instead.
Best regards,
Peter
7 Replies 7
Peter Paluch
Would you mind posting the complete configuration of the ingress and egress port?
Best regards,
Peter
ok Ill post it
its from that non cisco switch hope thats ok cli commands are very similar ...I am waiting on that 3550 which I belives needs some licensing to run QinQ
Ill post the config in a sec just reseting it
ok here is the config
this is not a CISCO config , so if you could just outline what i would need to do on a CISCO 3550 command wise to QinQ , double tag, all tagged packets coming in in the dot1q port so that they have 2 vlanid inner and outer (outer ==333) when they leave the egress port which is set up as a trunk port, and all untagged packet will just get the 1 tag 333 as they leave the trunk port
Aaaaagghhh please disregard this post my PIC in win7 was stripping the outer tag for me
a chance reboot into ubuntu reveals the truth on the qinq.
Sorry Paul
Best regards,
Peter
Yes I heartily agree ..I booted into my win7 image to fill in my time sheet (its a windows forms app) after doing so I thought id just continue on doing my testing work .... I marked your above statement as a correct anwswer
The configuration of the 3550 would be similar to this:
vlan 333
 name Customer
interface FastEthernet0/1
 description => Ingress Dot1Q Tunnel Port Toward a Customer <=
 switchport mode dot1q-tunnel
 switchport access vlan 333
interface FastEthernet0/2
 description => Egress Trunk <=
 switchport mode trunk
Best regards,
Peter
