QinQ frame format VS Ethernet frame
nnn_sss22
Please define me Ethernet frame and QinQ frame. what are the difference between them. thanks
Reza Sharifi
Have a look at this doc (figure-1).
http://www.cisco.com/c/en/us/td/docs/routers/10000/10008/feature/guides/qinq.html
Hello
I could not understand.
please tell me just headers of the ethernet frame with bytes .thanks
Have a look at these links for examples and explanations:
https://stackoverflow.com/questions/14812979/what-does-an-ethernet-header-look-like
https://wiki.wireshark.org/Ethernet
Austin Sabio
Level 4
Level 4
For comparison purposes. Good luck!
