QoS - Class-Map doesn't match the statement
I have create this class-map
887VA#show class-map
Class Map match-any DSN_SERVER (id 5)
Match access-group name DNS
That match this ACL
887VA#show access-lists DNS
Extended IP access list DNS
10 permit udp any eq domain any
20 permit udp any any eq domain
30 permit tcp any eq domain any
40 permit tcp any any eq domain
But when I apply it seems that doesn't match any packets
Class-map: DSN_SERVER (match-all)
0 packets, 0 bytes
30 second offered rate 0000 bps, drop rate 0000 bps
Match: access-group name DNS
Priority: 30% (16 kbps), burst bytes 1500, b/w exceed drops: 0
If I use the preconfigured cisco dns value for class map, seems working fine
Class Map match-all DNS (id 4)
Match protocol dns
Class-map: DNS (match-all)
166 packets, 16615 bytes
Match: protocol dns
  • Anyone can spot any errors in my first part of configuration?
  • The Match protocol dns match source or destination port 53?
7 Replies 7
Philip D'Ath
Meraki Community All-Star
It looks correct to me.
I did notice your first class-map was a "match-any" and the second was a "match-all" but this should not make any difference if there is only one match criteria.
Thanks for your reply. Do you know if the Match protocol dns match source or destination port 53?
Federico
I'm 80% confident it matches both.
the only thing I see is
Class-map: DSN_SERVER (match-all) <whereas should be match-any it is on my routers!
so are you sure you have
in the configuration
Found by myself. I did apply to interface instead to SVI.
A question for you guys:
Usually match both, but depends on your DNS setup,whether your DNS server has to go to a higher authority within  the DNS domain, or just receives requests from clients.
With your ACLs I would not have " any any" I would use the  addresses of the DNS servers
Thanks Richard.
My server is recursive, that means will use source and destination
