QoS command on 4948E switches
ankit.nigam
hi,
I have two 3750 switches and have to replace them with 4948E switches. The current 3750 switches have "mls qos"enabled in global mode but
the same command is not being accepted on the 4948E switches. Is there a way to configure " mls qos " on 4948E or is there an alternate command.
Thanks !!
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The 4948E has a (quite) different QoS architecture from the 3750 series.  The QoS commands are (quite) different.
Thanks Joseph !! Is there any alternate command for "mls qos" that you are aware of and can be used. The 3750 switches don't have QoS on the interface level just the global "mls qos" , QoS enabling command that I need to translate into 4948E switches.
Disclaimer
Posting
The 4948E should have global QoS commands that start with the keyword "qos".
Is there a simulator available to test 4948E commands on IOS 15.2(3) E.
hi Joseph,
On the global level these are the command options :
Switch(config)#qos ?
Global QoS configuration subcommands:
account              Additional lengths to be accounted by QoS Features
control-packets  Enable QoS on control packets
diffservmib         RFC3289 support for QoS policy-maps
preserve            Preserve packet header bits
Switch(config)#qos account ?
layer-all   All layers, including L1
layer2     Accounting Layer 2 headers
Switch(config)#qos account la
Switch(config)#qos account layer-
Switch(config)#qos account layer-all ?
encapsulation      Account Layer 1 Encapsulation when applying QoS features
CLTZ37S02(config)#auto qos ?
global    Global keyword
srnd4    QoS configurations based on solution reference network design 4.0
CLTZ37S02(config)#auto qos global ?
compact   Compact AutoQoS generated configurations
CLTZ37S02(config)#auto qos global co
CLTZ37S02(config)#auto qos global compact ?
<cr>
