Bookmark
Subscribe
682
Qos: Conditional Trust Model with a VLAN-Based QoS policy - approach and review
Markus Schwarz
Good day Cisco community,
I was wondering if someone has come across the following QoS implementation requirement ?
Subject : Qos: Conditional Trust Model with a VLAN-Based QoS policy - approach and review
Hardware in use:  Cat4500 Sup8 and Cat3850s
Just to recap; I have listed "Conditional Trust Model using Port-Based QoS" because this (in my view) is nicely/completely documented in the SNRD:
1) Conditional Trust Model using Port-Based QoS (Confirmed)
Standard LAN design followed “i.e.” Switch ports have been configured with DATA & VOICE VLANs
  •            Cisco Phone connects to Catalyst switch port Gig1/0/1
  •            PC connects to the Cisco Phone
Conditional trust rule applies, i.e.  trust COS-5 and COS-3 sent from the CISCO PHONE and ignore COS-0 (data received from the PC)
Sample configuration: (briefest form:)
class-map match-all VOICE
  match cos 5
class-map match-all SIGNALLING
  match cos 3
 policy-map LAN-CONDITIONAL-TRUST
    description ** User Access Switch VOICE & DATA port **
   class VOICE
    set dscp ef
   class SIGNALLING
    set dscp cs3
   class class-default
    set dscp default
interface Gig1/0/1
 description DATA & VOIP port
  x
  qos trust device cisco-phone
  service-policy input LAN-CONDITIONAL-TRUST
However, I have a requirement to enable "VLAN-Based QoS" so the Port-Based-QoS conditional trust QoS policy will go out the window because Port-Based-QoS policy takes precedence over VLAN-Based QoS
So I believe that the following configuration will need to be used but I am uncertain whether  this is best practise?. I failed to locate any documentation relating to conditional trust model using VLAN-Based QoS:
I would welcome any pointers or feedbackJ
2.) Conditional Trust Model using VLAN-Based QoS sample configuration draft I intent use deploy:  To be Confirmed
Cat4k#(brief config)  ** only Voice related:
  vlan 500
     name VOICE-LAN
ip access-list extended ACL-SIGNALLING
  remark ** SCCP **
  permit tcp any any range 2000 2002
  permit tcp any range 2000 2002 any
ip access-list extended ACL-VOICE
  remark ** RTP **
  permit udp any any range 16384 32768
Ip access-list extended ACL-DEFAULT
  remark ** Explicit classify the class default  **
  permit ip any any
class-map match-any VOICE-CLASS
  description ** QoS Class for Voice and  Conditional trust **
  match access-group name ACL-VOICE
  match cos 5   <<<<< Move and Match Cos 5 sent from Phone and thus simulate the conditional trust model as seen in point 1)
! class-map match-any SIGNALLING-CLASS
 description **  QoS Class for Signalling and Conditional trust **
  match access-group name ACL-SIGNALLING
  match cos 3 <<<<< Move and Match Cos 3 sent from Phone and thus simulate the conditional trust model as seen in point 1)
! class-map match-any DEFAULT-CLASS
 description **  QoS Class for Default traffic **
  match access-group name ACL-DEFAULT
policy-map VOICE-VLAN-BASED
  description ** VLAN-based QoS for Voice **
class VOICE-CLASS
  set dscp ef
class SIGNALLING-CLASS
  set dscp cs3
class DEFAULT-CLASS
  set dscp default
Apply the Policy to the VOICE VLAN (in Data base):
  vlan config 500
   service-policy input VOICE-VLAN-BASED
No action required on the interface:
Reason:  Cat4k does not support “mls qos vlan-based” at interface level. Instead it is attached to the VLAN database
interface Gig1/0/1
  x
I think this would be a fair approach although I am not 100% certain if this would be "Vlaid" and "best practice".
I would be grateful (and extremely delighted) if you could ping me back with any tips or advise,   If anyone has any knowledge if this implementation approach would be valid and indeed supported going forward.
Best Wishes
Markus
0 Replies 0
