QoS configuration for access and trunk ports
cmvictoria
I'm trying to fix all the QoS inconsistencies in our switch environment. Below are the configs that I think are correct to use. I'm looking for any feedback for improvement or lines that I could leave off. The Cisco phones that we primarily use are the 7962, 8841, and 8851. Video units are EX60, DX80, SX80 and spark room kits. Thank you in advance.
class-map match-all AUTOQOS_VOIP_DATA_CLASS
 match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
 match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
 match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
 class AUTOQOS_VOIP_DATA_CLASS
  set dscp ef
  police 128000 8000 exceed-action policed-dscp-transmit
 class AUTOQOS_VOIP_SIGNAL_CLASS
  set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
 class AUTOQOS_DEFAULT_CLASS
  set dscp default
  police 10000000 8000 exceed-action policed-dscp-transmit
Access Ports
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
 no snmp trap link-status
 mls qos trust device cisco-phone
 mls qos trust cos
 auto qos voip cisco-phone
 spanning-tree portfast
 service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
Trunk Ports
 priority-queue out
 mls qos trust dscp
 auto qos voip trust
 spanning-tree portfast disable
cmarva
Level 4
Level 4
I see you are using auto qos. Now, you don't specify the platform, so syntax will differ based on platforms. But with an OOB config (IE - blank), I let the switch do the work:
vlan 2
 name data
vlan 3
 name voice
auto qos srnd4
int range g1/0/1 - 24
switchport access vlan 2
switchport voice vlan 3
and the switch will auto generate the necessary config. You don't have to worry about creating your own. I have found some instances where auto qos isn't a good fit, but more often than not it works fine.
For switching purposes we're using 2960, 2960S and 2960X. The switches are strictly layer 2 traffic.
Would my trunk port configuration change?
