QoS default-class not using leftover bandwidth C9500
medina91
Hello
I am wondering if someone can check my policy configuration to see if there is any issue.
We are detecting output drops in all the active TenG interfaces of a C9500-16X, they are connected to some downstream switches with a 1G interfaces, the negotiation is obviously 1G and the utilization in the interfaces are not more than 20% and we have many packet drops.
The policy config  is:
policy-map out-queue
class Voice
priority level 1
police cir percent 30
conform-action transmit
exceed-action drop
class Protocols
bandwidth percent 5
class PriorData
bandwidth percent 25
class stream
bandwidth percent 10
class lesspriority
bandwidth percent 5
class class-default
The problem here is that there are many drops packets even though the load in the interface is not more than 8/255, As commented previously it is happening in several Catalyst C9500 As far as I know with the COS configuration implemented (CBWFQ + Bandwidth and LLQ Configuration), there shouldn't be any problem when the percent of the bandwidth used for the Class Default is bigger than the configured as this is the minimum bandwidth guarantee. But why is not using the leftover bandwidth?
We suspected that could be because the kind of traffic, that could be bursty and we changed the buffers allocation, but it didnt totally solved the issue. we configured "qos queue-softmax-multiplier 1200"
I activated the history utilization and drops in some of the interfaces an this are the results (attached image), you can see that we are dropping when the utilization is not more that 150mbits/sec
thank you in advance
Thank you, now I see. Total output drops show that there will be a problem with buffers.
More queue you create, less buffer memory is left per queue.
Here is a document, which will lead you to the solution.
Georg Pauwen did good advice. Tweak the output buffer.
7 Replies 7
in addition to increasing the softmax value, try and apply the service policy below to the interfaces that have the drops. Below is an example:
class-map match-any OUTPUT_CLASS
match access-group name OUTPUT_ACL
policy-map OUTPUT_POLICY
class class-default
bandwidth percent 100
interface GigabitEthernet1/0/3
service-policy output OUTPUT_POLICY
interface GigabitEthernet2/0/3
ip access-list extended OUTPUT_ACL
permit ip any any
Hello Georg
But with this configuration I will have just one Queue and there will not be prioritizing of the Voice, Video traffic, right?
Filip Po
Hello.
If interfaces are no more than 20 % utilized than no QoS drops should be on the line.
Post show interface command for a particular interface with drops.
Post show policy-map <policy-name> for a particular policy map applied on that interface.
Post show  policy-map interface <interface> for the same interface with drops.
Hello
Yeah in theory if I am not wrong, the default class should be able to use the 70% (100%-Voice Class) of the bandwidth if there is not traffic in the rest of the classes. Not sure why it is dropping if the utilization of the interface is so low
#show policy-map out-queue
Policy Map out-queue
Class Voice
priority level 1
exceed-action drop
Class Protocols
bandwidth 5 (%)
Class Data
bandwidth 25 (%)
Class stream
bandwidth 10 (%)
Class lesspriority
bandwidth 5 (%)
Class class-default
bandwidth 25 (%)
#show policy-map interface TenGigabitEthernet1/0/2 | i drops|band
(total drops) 0
(total drops) 0
bandwidth 5% (50000 kbps)
(total drops) 0
bandwidth 25% (250000 kbps)
(total drops) 0
bandwidth 10% (100000 kbps)
(total drops) 8504
(total drops) 4215209812
#show inter TenGigabitEthernet1/0/2
TenGigabitEthernet1/0/2 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is X
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is on, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 4215209812
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
30 second input rate 7422000 bits/sec, 1187 packets/sec
30 second output rate 5440000 bits/sec, 1210 packets/sec
13984292237 packets input, 16790176837929 bytes, 0 no buffer
Received 33701231 broadcasts (21282386 multicasts)
0 watchdog, 21282386 multicast, 0 pause input
9274003733 packets output, 4347665568329 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
245674 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
"Yeah in theory if I am not wrong, the default class should be able to use the 70% (100%-Voice Class) of the bandwidth if there is not traffic in the rest of the classes. Not sure why it is dropping if the utilization of the interface is so low"
As your wonder in your OP, it could be due to bursty traffic and a Catalyst 9500's architecture, both physical and logical. Catalyst 3K series switches has often not had lots of buffer RAM and their default QoS configuration often doesn't work well for ports dealing with microbursts. (If you initial configuration change somewhat mitigated the drop counts, and if you use Georg's recommendation, and if they also mitigates the drops, you'll have some confirmation of the issue of Cisco's architecture.)
"If interfaces are no more than 20 % utilized than no QoS drops should be on the line."
Surprisingly often, that's not true.
Utilization is generally an average over several minutes, while microbursts can have drops down in the millisecond range.
