Qos Design Recommendation
sebastiandm
Hi Guys,
I have a two remote sites each running call manager express with one site having only a 4MG ADSL connection to the internet therefore leaving only 512k for upstream traffic. There is also a vpn tunnel between the two sites.
Users are experiencing qos issues when making intersite calls jitter packet drops etc.
At the moment there is no qos deployed so i have come up with the following recommendation to prioritize the voice traffic.
class-map match-all Voice
match ip dscp ef
class-map match-any Call_Signalling
match ip dscp cs3
match ip dscp af31
policy-map WAN-EDGE
class Voice
priority percent 20
class Call_Signalling
bandwidth percent 5
class class-default
fair-queue
interface fastethernet 0/1
service-policy output WAN-EDGE
I would like to know if there is any other mechanism i can use and if the above recommendation will be sufficient to resolve the qos issues on this link...thanks.
johnlloyd_13
Level 9
Level 9
Joseph W. Doherty
For QoS to be effective, it needs to match available bandwidth. In this case, you'll want a hierarchical policy with a shaper for the 512 Kbps.
e.g.
policy-map shape512
class class-default
!shape slower than nomimal bandwidth to allow for Ethernet overhead
shape avg 450000
service-policy WAN-EDGE
service-policy output shape512
As the other poster (John) noted, if you're using VPN, you could use the QoS preclassify command. Since you're using DSCP tags for matching, you voice traffic would be recognized, but class-default would only see one flow w/o preclassify for all your VPN traffic.
I recommend against using FQ with non-LLQ defined classes. I would suggest you either place the call signaling traffic into the LLQ or just let FQ handle it.
