QoS in 6500 supervisor 2t & 4500X ver 15
s.persson
I hav todat the following config for ex, int 3560 switchar and 3750
Global:
mls qos
At the interface:
switcport mod access
auto qos voip trust
mls qos trust dsco
and also on other interface:
switchport mode trunk
mls qos trust dscp
auto qos voip trust
What commands should i use in 6500  sup.2T och 4500x with ver 15
too ge t same function?
it is not support with mls in these products
Reza Sharifi
That is correct.  There is no more "mls qos" command with PFC-4 (Sup 2T).
try:
show auto qos default
and have a look at this document for all changes in Sup-2T qos architecture.
Also see table-8:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-652042.html
Thank you för the answer
So you mean that i shall use the command
auto qos default
as a global command?
Does i need some command under the interface?
does the queueing  work?
I dont think that i can use trust dscp then the interface is a switchport, only then the port is a route port
but will it work all the same?
SP
With Sup-2T, the interfaces by default trust DSCP.
do a "show queueing interface gix/xx and look for
Trust state: trust DSCP
Trust state in queueing: trust COS
What commands should i use in 4500x switches?
You cant use the command
Then it by  default trust DSCP,
Does i need to config a policymap under the interface?
What queue will it use if ?
sp
