QOS marking policy doesn't match on N7K
gilou_1973
Hello
I have a pair of Nexus 7K's running 6.0(1).
I have a handful of edge devices (Blades switches, CAtalyst switches)that I need to mark ingress traffic.
I've created and attached a very simple policy to the port-channel and noting matches in the Policy.
It's confirmed further in the backbone when I capture the traffic, the datas are still marked to default.
Here under is my configuration:
policy-map type qos test
    class  test
      set dscp cs2
class-map type qos match-any test
      match access-group name test
IP access list test
        10 permit tcp any any eq telnet
        20 permit tcp any eq telnet any
interface port-channel14
  description C2960-N-60.riziv.be
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 1,11-12,14-15,40,90
  spanning-tree guard root
  mac packet-classify
service-policy type qos input test
  vpc 14
  layer2-switched flow monitor v9_l2_standard input
Nexus_1# sh policy-map int po 14 type qos
Global statistics status :   enabled
port-channel14
  Service-policy (qos) input:   test
    SNMP Policy Index:  285216008
    Class-map (qos):   test (match-any)
     Aggregate forwarded :
      0 packets  0 bytes
      Match: access-group test
        0 packets
      set dscp cs2
I've generated traffic but as you can see packet counters remains null.
Any idea about my mistake?
By advance thanks
7 Replies 7
Jerry Ye
Did you put the QoS policy on both vPC peering switches??? Traffic might hit the other switch through the other vPC.
I tested this in my lab switch and the counter is increaming correctly for me. I am running 5.2(4) right now.
jerry
Hello Jerry,
Yes, absolutely I've put the QOS on both N7K.
Do you think that it can be linked to the Line Card module.
I've set  it on a M148GT-11 card.
I'm going to test it on another line card and give you a feedback.
Another questions:
- When you do a " sh policy-map int po xx type qos", do you see matches ?
- Do you also have two input policies on your port, a queuing policy (the default one) and a qos policy?
Gildas
port-channel14
      0 packets  0 bytes
        0 packets
      set dscp cs2
  Service-policy (queuing) input:   default-in-policy
    SNMP Policy Index:  301992025
    Class-map (queuing):   in-q1 (match-any)
      queue-limit percent 50
      bandwidth percent 80
      queue dropped pkts : 0
    Class-map (queuing):   in-q-default (match-any)
      bandwidth percent 20
Hello Jerry,
I've just tested on another line card, model
N7K-M148GS-11L
Same way, marking doesn't work.
Gildas
Can you ask how did you do your test?
jerry
I just realized the problem.
  switchport
  mac packet-classify <<<<< This is what causing it
  vpc 14
I know you might need the mac packet-classify for other feature, like L2 netflow. My test doesn't have this on and it is working for me. If you removed that, it should be able to classify packets.
jerry
Hello Jeye,
You're right Jeye.
I removed it from the interface and I can see matches in my qos policy.
And i's confirmed by packet capture, packets are well marked.
Does it mean that Netflow work no more for this interface?
Thanks a lot for your help.
Gildas
Yes, since your NetFlow is L2 based. All L2 based traffic classification needs to use the mac packet-classify to make it to work. This includes L2 NF, L2 VLAN filters (VACL), etc.
HTH,
jerry
