QoS: Need help with MQS
haji_akhundov
Hello everyone!
I would like to know what I'm doing wrong here: on the serial interface I have this 'policy-map output serial' applied. Although I have specified bandwidth percent 50, it seems that it's using all 100. I later tried changing that value from 50 to 10, 20, 30 etc. and it's all the same. It just prioritizes all the DSCP af11 packets and ignores (sort of drops) all other unmarked packets. Is there something else that must be written in the class class-default?
p.s. I used jperf to check this.
Any help is appriciated!
class-map match-all dscpAF11
match  dscp af11
class-map match-all HI-PRI
match cos  5
policy-map serial
class dscpAF11
class class-default
  fair-queue
policy-map marker
class HI-PRI
  set dscp af11
interface FastEthernet0/0.3
encapsulation dot1Q 3
service-policy input marker
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 172.23.0.2 255.255.255.252
service-policy output serial
7 Replies 7
cadet alain
all this will do is guarantee 50 % of bandwidth to traffic marked with AF11 only in case of Congestion.
But as long as there is no congestion this will have no effect.
Regards.
Alain
Dear Alain,
I understand this. But why is it dropping all other traffic that is not marked with AF11?
Haji
what do you mean by that:
Post following sh policy-map interface f0/0.3 and sh policy-map interface s0/0/0
Regards.
Alain
Router1#show policy-map interface f0/0.3
FastEthernet0/0.3
  Service-policy input: marker
    Class-map: HI-PRI (match-all)
      5542530 packets, 2485604057 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: cos  5
      QoS Set
        dscp af11
          Packets marked 5542530
    Class-map: class-default (match-any)
      88560 packets, 81356616 bytes
      Match: any
Router1#show policy-map interface s0/0/0
Serial0/0/0
  Service-policy output: serial
    Class-map: dscpAF11 (match-all)
      4390915 packets, 1137861836 bytes
      Match:  dscp af11 (10)
      Queueing
        Output Queue: Conversation 265
        Bandwidth 50 (%)
        Bandwidth 772 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 664061/935814284
        (depth/total drops/no-buffer drops) 0/0/0
      51232 packets, 43152697 bytes
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/0/0
But nothing is running at the moment, I mean no data streams. Hope it helps you to help me
I need these infos when you use jperf to do the Qos testing and also how you do the testing and what results you find abnormal.
Regards.
Alain
Dear Alain,
I have attached a file that shows how I did the testing and where I see abnormalities.
Thank you again.
Alain,
I fixed this issue by replacing this:
policy-map serial
class dscpAF11
class class-default
  fair-queue
with
policy-map serial
class dscpAF11
class class-default
  bandwidth percent 25
Now other unmarked packets don't get droped.
I would still like to know why wasn't it working previously. Also I am wondering should I have a parent policy that has a shaper? What are the benefits and usage of it?
