Qos On 3850 Switch GRE
liordoanis
I need help with configuring Qos on 3850 switch,
the problem is that the 3850 switch have a WAN link connected with GRE connection
to another router.
Now from my understanding, 3850 does not support Qos over GRE tunnel,
is there a solution for this situation?
many thanks
P.S , if I will configure "qos pre-classfiy" command on the tunnel interface
and will assigned a policy-map to the physical interface that is connected to the GRE tunnetl
will it solve my question?
0 Replies 0
