QOS on Cisco 7604
kennya7000
Looking to classify/mark with MQC/IP NBAR on ingress and CBWFQ on egress with following configuration, appreciate any feedback or input:
Mls qos
Classification/Marking
class-map match-all WAN-Business-3-Mark
match protocol citrix
class-map match-all WAN-Premium-2-Mark
match protocol rtp video
class-map match-all WAN-Premium-1-Mark
match protocol rtp audio
class-map match-all WAN-Best-Effort-Mark
match access-group name default-0
policy-map QoS-Mark
class WAN-Premium-1-Mark
  set ip dscp ef
class WAN-Premium-2-Mark
  set ip dscp af41
class WAN-Business-3-Mark
  set ip dscp af11
class WAN-Best-Effort-Mark
  set ip dscp default
ip access-list extended default-0
permit ip any any
interface Vlanx
description x
ip vrf forwarding x
ip address x.x.x.x x.x.x.x
ip nbar protocol-discovery
service-policy input QoS-Mark
CBWFQ
class-map match-all WAN-Premium-1-(Voice)
match ip dscp ef
class-map match-all WAN-Premium-2-(Video)
match ip dscp af41
class-map match-all WAN-Business-3-(Citrix)
match ip dscp af11
class-map match-all WAN-Best-Effort-(Default)
match ip dscp 0
policy-map WAN-QoS
class WAN-Premium-1-(Voice)
  priority x
class WAN-Premium-2-(Video)
  bandwidth x
class WAN-Business-3-(Citrix)
  bandwidth x
class WAN-Best-Effort-(Default)
fair-queue
interface Vlanx
description x
ip vrf forwarding x
service-policy output WAN-QoS
Pronoy Dasgupta
The usage of QoS on the 7600 and the 6500 to a huge extent on the line cards being used.
Could you give me the output of show module and show version that is currently in use on the 7600?
7600 follows Catalyst QoS, and is implemented in hardware, which means most of the options that you have used here in the policy maps are not supported since they are part of the MQC QoS schema.
For further information refer to this link:
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html#wp1481044
Implementatio of QoS also depends on the kind of line cards being used. ES+ line cards do support full MQC QoS.
Pronoy
Thanks for feedback Pronoy,
info as requested:
Mod Ports Card Type                              Model              --- ----- -------------------------------------- ------------------ -----------
  1    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  4    0  4-subslot SPA Interface Processor-400  7600-SIP-400
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD4, RELEA                                          SE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
looking at the SIP-400 capability, following should be possible supporting MQC marking and CBWFQ
Cisco 7600 SIP-400 Packet Marking
IP precedence (set ip precedence command)—Input and output
DSCP (set dscp command)—Input and output
Class-based marking
DE to EXP marking/ToS/DSCP
CLP to EXP marking/ToS/DSCP
Ethernet 802.1q priority bits to EXP marking (EoMPLS)
Cisco 7600 SIP-400 Classification Into a Queue
Access control lists (IPv4 and IPv6)
Access group (match access-group command)—Input and output
Address (IPv6 compress mode only)
Name
Number
Source and destination port
TCP flag (IPv4 only)
ATM CLP (match atm clp command)—Input ATM interface
Configurable queue size
CoS (match cos command)—Input and output dot1q tagged frames for 2-Port Gigabit Ethernet SPA only
Frame Relay DE (match fr-de command)—Input Frame Relay interface
Inner CoS (match cos inner command)
IP DSCP (match dscp command)—Input and output
IP precedence (match ip precedence command)—Input and output
MPLS EXP (match mpls experimental command)—Input and output MPLS interface
Multiple matches per class map (up to 8)
Cisco 7600 SIP-400 Congestion Management
CBWFQ
Per-VC CBWFQ
DSCP, EXP and Precedence matching
LLQ or priority queueing (strict priority only)
Dual-priority queuing
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a008044013b.html#wp1094663
