Qos on Nexus 9300 (NXOS)
jason_majie
Hi There:
i have a simple setup. 1 x N9372TX-E, the 48 x 1/10G Base-T will connect to servers, and 6 x QSFP ports will be used for uplink to upper layer network equipment.
all the 48 x 1/10G base-T port will have QOS marking policy, and on uplink port (qsfp port), the switch suppose to do egress queue based on the marking.
but i read the ALE port on the N9K does not support egress qos policies.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/ale_ports/b_Limitations_for_ALE_Uplink_Ports_on_Cisco_Nexus_9000_Series_Switches.html
but meanwhile i read another document it mentioned "Egress Queues on ALE and ALE-2 40 Gigabit Ethernet Ports"
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/white-paper-c11-732452.html#_Toc401968150
it shows you can assign traffic to different user define qos group, but seams they do not have difference in priority.
in this case, is there any way i can prfioritize traffic and queue out accordingly?
0 Replies 0
