QOS: Packets not market at inboung interface??? Strange
m.musacchio
Hello to all, is possible that packet could no be marked inbound fa0/0
For example
(R1)s0/0/0 <--> s0/0/0 (R2)
(R1)s0/1/0 <--> s0/1/0 (R2)
Two routers connected through two serial interface in load sharing per packet.
this is the conf for R2:
class-map match-all HTTP
match protocol http
class-map match-all DSCP-AF33
match ip dscp af33
policy-map HTTP
class HTTP
set ip dscp af33
policy-map DSCP-AF33
class DSCP-AF33
interface FastEthernet0/0
service-policy input HTTP
R3
match ip dscp af33
class DSCP-AF33
interface Serial4/5:0
service-policy input DSCP-AF33
interface Serial5/6:0
show in R2
FastEthernet0/0
Service-policy input: HTTP
Class-map: HTTP (match-all)
30963 packets, 6113447 bytes
30 second offered rate 41000 bps, drop rate 0 bps
Match: protocol http
QoS Set
dscp af33
Packets marked 30963
Class-map: class-default (match-any)
355690 packets, 263701909 bytes
30 second offered rate 160000 bps, drop rate 0 bps
Match: any
The packet seems to be market as them enter the f0/0
On R1
Serial0/0:0
Service-policy input: DSCP-AF33
Class-map: DSCP-AF33 (match-all)
0 packets, 0 bytes
30 second offered rate 0 bps
Match: ip dscp af33
Serial0/1:0
0 packets, 0 bytes
Match: ip dscp af33
Now if I put the marking out (instead in of the f0/0) of the serials of R2
R2
interface Serial0/0/0
service-policy output HTTP
interface Serial0/1/0
After a Clear counters you will see on Router R1:
Serial0/0:0
18 packets, 4781 bytes
Match: ip dscp af33
2962 packets, 404307 bytes
30 second offered rate 60000 bps, drop rate 0 bps
Match: any
Serial0/1:0
20 packets, 4495 bytes
Match: ip dscp af33
3251 packets, 451178 bytes
30 second offered rate 63000 bps, drop rate 0 bps
Match: any
Why marking is not working when I apply it inbound of the f0/0 ?.....
Best Regards!
Kevin Dorrell
Level 10
Level 10
Are these routers connected together through a switch that is, itself, running mls qos? If so, have you put mls qos trust dscp on the router ports? If you don't, then the switch will strip the DSCP.
(Unless I have misunderstood the architecture, in which case I apologise, and could you sketch it out please. I'm not clear where R3 fits in.)
Kevin Dorrell
Luxembourg
Sorry I made a mistake when cutting and pasting :)
---------WRONG------------
R3
match ip dscp af33
class DSCP-AF33
-----------END-----------------
----------CORRECT------------
R1
match ip dscp af33
class DSCP-AF33
when you use match protocol http you are actually using NBAR (Network Based Application Recognition)
depending on the IOS version to have NBAR to work correctly you need to enable NBAR protocol discovery on the interface.
see for example:
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/nbar_protocl_discvry_ps6922_TSD_Products_Configuration_Guide_Chapter.html
you can do it using :
interface type number [name-tag]
ip nbar protocol-discovery
Hope to help
Giuseppe
