QOS per VLAN IN Switch 3850
Hi Dear Friend I have switch 3850 with Trunk port
No i want Limit VLAN BW Per vlan
note: Switch is Layer 2 Only
I want  pilocy any trafiic TX OR RX on vlan 34 For example
VLAN 34 Shapping 60M TX and 60M RX
THX
6 Replies 6
Thx For your help but
I want apply Different QOS on Different VLANS
For example vlan 34 10M
VLAN 33 5M
And apply On Trunk Port Interface
i Assign only One Service policy on Physical Trunk Interface
Please Help me
My config is:
class-map vlan 34
match vlan34
policy-map vlan 34
class vlan 34
police 10000000 bc conform-action transmit exceed-action drop
end
Now Assign policy-map on Trunk physical Interface
interface tengigabit 1/0/7
service-policy input vlan34
service-policy output vlan34
But Not working
Nadav
Level 7
Level 7
Cisco switches aren't quite routers, even if IOS-XE would have you believe that anything goes ;)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-8/configuration_guide/qos/b_168_qos_3850_cg.pdf
If you want to use policy-maps for bandwidth, you do it per port and not per SVI. You can use SVI's for marking, sure, but not for bandwidth restrictions.
The supports a VLAN QoS feature that allows the user to perform QoS treatment at the VLAN level
(classification and QoS actions) using the incoming frame’s VLAN information. In VLAN-based QoS, a
service policy is applied to an SVI interface. All physical interfaces belonging to a VLAN policy map then
need to be programmed to refer to the VLAN-based policy maps instead of the port-based policy map.
Although the policy map is applied to the VLAN SVI, any policing (rate-limiting) action can only be performed
on a per-port basis. You cannot configure the policer to take account of the sum of traffic from a number of
physical ports. Each port needs to have a separate policer governing the traffic coming into that port.
Thank you For attention
Please Help me
How limit BandWitdh Of VLANS (layer 2 Switch work only )
In switch 3850???
You don't, at least not on the switch directly. Here are some alternatives:
One option is a router on a stick:  send all VLANs to the gateway and apply a policy-map per subinterface. This assumes that traffic isn't being switched on the L2 switch between access ports, doable via proxy-arp on router and private-vlans/protected ports on the switch, so all traffic from these VLANs goes up to the router and is there being policied. Make sure the router port isn't a bottlneck.
Another option: Ugly ugly option. Each access port from the switch (S1) will be a single-vlan trunked to a second switch (S2). Each physical port on S1will have its own policy. They are aggregated at S2 and then sent along via a 802.1q. Make sure not to oversubscribe the downlink at S2.
Hi Dear You Say donnot have any solution For Limit Traffic VLAN In switch 3850???? In trunk Mode
