QOS , Policing | need help
musthafa786
Based on below diagram , Is the confiuration correct in switch SW1  for policing 1mb data when communicate from 192.168.10.0/24 subnet to 192.168.20.0/24  ?
SW1 is purely L2 switch ( no routing). Distribution switch SW3 is having vlan interface for vlan 10 and 20 and ip  192.168.10.1 and 192.168.20.1 respectively, thanks.
Here is SW1 conf iguration:
spanning-tree mode rapid-pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 10
class-map match-all Critical
match access-group name Critical
policy-map Policy-QoS
class Critical
  police 10000000 8000 exceed-action drop
  set dscp cs3
class class-default
  set dscp default
interface FastEthernet1/0/1
switchport access vlan 10
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input Policy-QoS
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface GigabitEthernet1/0/1
description UPlink
switchport trunk allowed vlan 10
switchport mode trunk
mls qos trust cos
ip access-list extended Critical
deny   icmp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
deny   ip any any
musthafa786
This is just a doubt , Can I use access list with matching IP hosts for packet clasification in Layer 2 switch ( no routing ) ?
Musthafa
